×Hi
I am using Jira Service Desk (server edition) with its license expired.
I know that I am not supposed to update as my license has expired but someone went to update JIRA to v8.11.0.
Jira Service Desk is not updated. It is now at v4.3.0
I only come to know about the update as side bar for JIRA service desk is not loading. I think it is caused by incompatibility between JIRA and JIRA Service Desk versions.
https://confluence.atlassian.com/jiracore/jira-applications-compatibility-matrix-975041287.html
So now, what should I do?
Downgrade JIRA?
Update JIRA Service DesK?
Thanks!
Hi Koh,
whilst I understand this is an unpleasant scenario I just wanted to note that a downgrade of Jira is most likely leading to additional trouble.
Once the database structures are updated (which is likely the case when you upgrade to v8.11) a lower version will have problems.
To which extend is something that cannot be stated but a downgrade is the least option I would undertake.
If you can update JSD/JSM to a more recent version is not something that could be recommend here without further information. In any case you should test first on a non-production environment.
But - basically - yes, from the compatibility guide this is a non-match at the moment.
In case you prefer a roll back (please note the implications as, for example, data loss for all data brought in since upgrade) please refer to the following guidelines:
https://confluence.atlassian.com/adminjiraserver/rolling-back-a-jira-application-upgrade-938846960.html
Daniel
