Jira smart value for total of incomplete subtasks story point estimates
Nipuna Madushanka
October 5, 2022
I'm trying to automatically update Story Point Estimate of Parent user story with total of incomplete subtasks (Status not in "Done") Story Point Estimates.
I could able to automatically update Story Point Estimate of Parent user story with total of all subtasks (Not considering its status) Story Point Estimates as follows.
Used Smart Value :
"fields": {
"Story point estimate": {{#=}}{{issue.Story point estimate.join(" + ")}}{{/}}
As the same Jira automation, I'm searching for a solution to capture total of incomplete subtasks (Status not in "Done") Story Point Estimates.
Stefan Salzl
Hi @Nipuna Madushanka
regarding your description I assume you are working in a team-managed project.
Furthermore I get the requirement as follows:
- when the field "Story point estimate" of a subtask changes
- then the rule should sum "Story point estimate" of all subtasks within the same parent which are not done
- and populate this sum in the parent´s "Story point estimate" field
If I got that right the following rule should do the work:
Please let me know if this was helpful and if you have any further questions.
Best
Stefan
