Jira upgrade error and failed to start (Jira does not support zero downtime upgrades)
Dmitriy Voznesenskiy July 1, 2022
Dear Team
Jira Service Management 4.22.2 plan to upgrade to 5.0.0
We use CloudFormation in AWS, with zero downtime
Steps:
1) We put Jira 4.22.2 to upgrade mode
2) Run one more node with jira 5.0.0 using CloudFormation
3) Delete the node with 4.22.2 manually
We are trying to open jira(open white screen with following address: https://...........com/secure/errors.jsp, and receive the following errors in logs:
2022-07-01 16:32:43,662+0000 main ERROR      [c.a.jira.startup.LauncherContextListener] Unable to start JIRA.
java.lang.IllegalStateException: Your node with Jira version 9.0.0 will not start up with version 8.22.2 because Jira does not support zero downtime upgrades between major releases. See https://docs.atlassian.com/jira/jadm-docs-080/Upgrading+Jira+applica$
        at com.atlassian.jira.startup.ClusterNodeVersionCheckLauncher.verifyMajorVersion(ClusterNodeVersionCheckLauncher.java:85)
        at com.atlassian.jira.startup.ClusterNodeVersionCheckLauncher.start(ClusterNodeVersionCheckLauncher.java:71)
        at com.atlassian.jira.startup.DefaultJiraLauncher.lambda$postDbLaunch$2(DefaultJiraLauncher.java:142)
        at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrEnqueue(DatabaseConfigurationManagerImpl.java:307)
        at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrWhenDatabaseActivated(DatabaseConfigurationManagerImpl.java:202)
        at com.atlassian.jira.startup.DefaultJiraLauncher.postDbLaunch(DefaultJiraLauncher.java:135)
        at com.atlassian.jira.startup.DefaultJiraLauncher.lambda$start$0(DefaultJiraLauncher.java:102)
        at com.atlassian.jira.util.devspeed.JiraDevSpeedTimer.run(JiraDevSpeedTimer.java:31)
        at com.atlassian.jira.startup.DefaultJiraLauncher.start(DefaultJiraLauncher.java:100)
        at com.atlassian.jira.startup.LauncherContextListener.initSlowStuff(LauncherContextListener.java:154)
        at com.atlassian.jira.startup.LauncherContextListener.initSlowStuffInBackground(LauncherContextListener.java:139)
        at com.atlassian.jira.startup.LauncherContextListener.contextInitialized(LauncherContextListener.java:101)
        ... 5 filtered
        at java.util.concurrent.FutureTask.run(FutureTask.java:266)
        at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75)
        at java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:134)
        ... 5 filtered
        ... 11 filtered
        at java.lang.reflect.Method.invoke(Method.java:498)
        ... 2 filtered
Dmitriy Voznesenskiy July 4, 2022
Solution
1) install older version of jira 4.22.2 (
sudo tar zxf atlassian-servicedesk-4.22.2.tar.gz -C /opt/atlassian/jira-servicedesk/4.22.2/ --strip-components 1)
2) unzip it
3) copy all files from
JIRA_HOME="/var/atlassian/application-data/jira"
to new jira home (to connect DB)
4) Start jira server on 4.22.2
5) Stop upgrade mode
6) Run jira.service with ok
Bastian Stehmann
Hi @Dmitriy Voznesenskiy ,
As the error message in the log states, Zero Downtime Updates are not supported for major release changes.
So for the upgrade to 5.0.0you need a Downtime.
Dear Bastian
Yes, as jira UI interface didn't work, what my next steps to run it. it installed on UBUNTU server and when i manually start jira.service- i got an error.
