Method to add ticket location
Alexandra_Groza
May 16, 2024
We're just implementing the ticketing system through Jira cloud and it would be very useful to have a way to automatically generate ticket location so teams across the globe can quickly pick up the most urgent issues.
I have two methods i can think of now:
1. A way to automatically import users location when syncing with Entra
2. Have an option to generate a dynamic column in the queues depending on IP
Which one do you think it's more doable?
Jeroen Poismans
Hi there and Welcome to the Community!
There are some services online where you can make a REST call with an IP and you get a JSON with geolocation data as a response.
Example, this one is free:
https://ip-api.com/docs/api:json
Request:
http://ip-api.com/json/24.48.0.1
Gives this response:
  "query": "24.48.0.1",
  "status": "success",
  "country": "Canada",
  "countryCode": "CA",
  "region": "QC",
  "regionName": "Quebec",
  "city": "Montreal",
  "zip": "H1S",
  "lat": 45.5909,
  "lon": -73.5655,
  "timezone": "America/Toronto",
  "isp": "Le Groupe Videotron Ltee",
  "org": "Videotron Ltee",
  "as": "AS5769 Videotron Ltee"
From Automation you could do this request on issue create, capture the response, extract what you want and put it in a field on the created ticket. Pretty cool :-)
Jeroen
Alexandra_Groza
May 19, 2024
Thank you,
We decided to import the location attribute from Entra
Retrieving location from public IP was not an option anyway
