×Hello,
We need to create an automation rule that: when a specific transition is done for an issue, we need to move its child elements to another project.
We have got that when the issue is transitioned, its child elements are cloned to the other project, however we don't know how to remove the original issues. How can we do it?
Thanks!
Hi @[deleted]
In automation there is not action like move issue. What you can do is copy issue to destination project and delete source issue.
Seba
Hi @[deleted] try adding step "Remove Issue" after the cloning step in your automation
