×This question is in reference to Atlassian Documentation: Configuring a custom field
I'd like my custom field to show up in the issue detail view, even if there is no value set up for it.
I can't get it to show up.
No, it won't appear until you have got data in it. JIRA hides empty fields in an attempt to reduce screen clutter.
I think you can always work around that for your specific field by:
I assume "my custom field" means that you have implemented it. In this case, in order to provide a default value, implement the method: com.atlassian.jira.issue.customfields.impl.AbstractSingleFieldType#getDefaultValue(com.atlassian.jira.issue.fields.config.FieldConfig)
Hi Maria,
do you mean the detail view of the agile board? If so, you have to add the field to the detail view in the board configuration:
Thomas
This is a normal behavior, only custom fields with values will be shown. You can't change it.
