Need to remove system comment field from transition screen
Deleted user November 5, 2015
I need to remove the system comment field from my transition screens as I'm using a custom field for comments and having both comment fields is confusing tot he end user.
i found this:
<script type="text/javascript">
if(AJS.$('#issue-workflow-transition-submit').val() =='Assign'){
AJS.$('div.comment-input').css('display', 'none');
</script>
but it removes the system comment field from the View Screen as well as the transitions.  is there a way to ONLY remove system comment field from a transition screen?
Also, why is the system comment field mandatory???
Thank you
Joe Torres (Admin) June 21, 2016
This would be a big help in my projects as well.
ChrisR
I'd like to know this as well.
