Next-gen project automation assign an Epic
Jonathan_Kaczynski
January 15, 2019
In the automation section of a new next-gen project, I am trying to conditionally assign new tickets to a specific epic, but it is failng with the error "gh.epic.error.not.found".
When I configure the "Then" section of the automation, in specifying the target Epic Link, the text entry box turns my epic name into the issue id, DATA-1.
Comparing this to the "Add to Epic" flow which goes by the the issue name, not the issue id, I hypothesize that there's a potential bug in Automation configuration. If next-gen projects handle epic assignment purely by name, then the configuation text shouldn't have replace my desired epic/issue name with the related issue id.
Vasi
March 4, 2019
Hey Jonathan,
It's been quite some time, so I just wanted to check if you still experience this issue.
I was trying to configure something similar to what you are describing, however not entirely sure how you are configuring automation rule.
Could you please provide some screenshots and also specific conditions you were using?
I will try to reproduce it and file a bug if needed.
Vasily
