Im using CentOS 7.
I installed JIRA from the .bin file
sudo mkdir /opt/atlassian cd /opt/atlassian/
sudo wget https://downloads.atlassian.com/software/jira/downloads/atlassian-jira-software-7.9.2-x64.binsudo chmod +x atlassian-jira-software-7.9.2-x64.bin
sudo ./atlassian-jira-software-7.9.2-x64.bin
Im trying to setup HTTPS following this link
I am trying to run config.sh
cd /opt/atlassian/jira/bin
./config.sh
I get the error
No JRE_HOME or JAVA_HOME environment variable is set - attempting to just run java command
********** Wrong JVM version! You are running with .. but JIRA requires at least 1.8 to run. **********
I have followed this
https://jira.atlassian.com/browse/JRASERVER-21502
JAVA_HOME=/opt/atlassian/jira/jre
Still get the above error.
Checked java version
# /opt/atlassian/jira/jre/bin/java -version
java version "1.8.0_102"
Java(TM) SE Runtime Environment (build 1.8.0_102-b14)
Java HotSpot(TM) 64-Bit Server VM (build 25.102-b14, mixed mode)
I followed this
https://jira.atlassian.com/browse/JRASERVER-43770
[root@JIRA-Server bin]# cd /opt/atlassian/jira/bin
[root@JIRA-Server bin]# ./setenv.sh
.... .NMMMD. ...
.8MMM. $MMN,..~MMMO.
.?MMM. .MMM?.
OMMMMZ. .,NMMMN~
.IMMMMMM. .NMMMN. .MMMMMN,
,MMMMMM$..3MD..ZMMMMMM.
=NMMMMMM,. .,MMMMMMD.
.MMMMMMMM8MMMMMMM,
.ONMMMMMMMMMMZ.
,NMMMMMMM8.
.:,.$MMMMMMM
.IMMMM..NMMMMMD.
.8MMMMM: :NMMMMN.
.MMMMMM. .MMMMM~.
.MMMMMN .MMMMM?.
Atlassian JIRA
Version : 7.9.2
If you encounter issues starting or stopping JIRA, please see the Troubleshooting guide at http://confluence.atlassian.com/display/JIRA/Installation+Troubleshooting+Guide
Server startup logs are located in /opt/atlassian/jira/logs/catalina.out
[root@JIRA-Server bin]# set
BASH=/bin/bash
BASHOPTS=checkwinsize:cmdhist:expand_aliases:extquote:force_fignore:histappend:hostcomplete:interactive_comments:login_shell:progcomp:promptvars:sourcepath
BASH_ALIASES=()
BASH_ARGC=()
BASH_ARGV=()
BASH_CMDS=()
BASH_LINENO=()
BASH_SOURCE=()
BASH_VERSINFO=([0]="4" [1]="2" [2]="46" [3]="2" [4]="release" [5]="x86_64-redhat-linux-gnu")
BASH_VERSION='4.2.46(2)-release'
COLUMNS=166
DIRSTACK=()
EUID=0
GROUPS=()
HISTCONTROL=ignoredups
HISTFILE=/root/.bash_history
HISTFILESIZE=1000
HISTSIZE=1000
HOME=/root
HOSTNAME=JIRA-Server
HOSTTYPE=x86_64
ID=0
IFS=$' \t\n'
LANG=en_GB.UTF-8
LESSOPEN='||/usr/bin/lesspipe.sh %s'
LINES=22
LOGNAME=root
LS_COLORS='rs=0:di=38;5;27:ln=38;5;51:mh=44;38;5;15:pi=40;38;5;11:so=38;5;13:do=38;5;5:bd=48;5;232;38;5;11:cd=48;5;232;38;5;3:or=48;5;232;38;5;9:mi=05;48;5;232;38;5;15:su=48;5;196;38;5;15:sg=48;5;11;38;5;16:ca=48;5;196;38;5;226:tw=48;5;10;38;5;16:ow=48;5;10;38;5;21:st=48;5;21;38;5;15:ex=38;5;34:*.tar=38;5;9:*.tgz=38;5;9:*.arc=38;5;9:*.arj=38;5;9:*.taz=38;5;9:*.lha=38;5;9:*.lz4=38;5;9:*.lzh=38;5;9:*.lzma=38;5;9:*.tlz=38;5;9:*.txz=38;5;9:*.tzo=38;5;9:*.t7z=38;5;9:*.zip=38;5;9:*.z=38;5;9:*.Z=38;5;9:*.dz=38;5;9:*.gz=38;5;9:*.lrz=38;5;9:*.lz=38;5;9:*.lzo=38;5;9:*.xz=38;5;9:*.bz2=38;5;9:*.bz=38;5;9:*.tbz=38;5;9:*.tbz2=38;5;9:*.tz=38;5;9:*.deb=38;5;9:*.rpm=38;5;9:*.jar=38;5;9:*.war=38;5;9:*.ear=38;5;9:*.sar=38;5;9:*.rar=38;5;9:*.alz=38;5;9:*.ace=38;5;9:*.zoo=38;5;9:*.cpio=38;5;9:*.7z=38;5;9:*.rz=38;5;9:*.cab=38;5;9:*.jpg=38;5;13:*.jpeg=38;5;13:*.gif=38;5;13:*.bmp=38;5;13:*.pbm=38;5;13:*.pgm=38;5;13:*.ppm=38;5;13:*.tga=38;5;13:*.xbm=38;5;13:*.xpm=38;5;13:*.tif=38;5;13:*.tiff=38;5;13:*.png=38;5;13:*.svg=38;5;13:*.svgz=38;5;13:*.mng=38;5;13:*.pcx=38;5;13:*.mov=38;5;13:*.mpg=38;5;13:*.mpeg=38;5;13:*.m2v=38;5;13:*.mkv=38;5;13:*.webm=38;5;13:*.ogm=38;5;13:*.mp4=38;5;13:*.m4v=38;5;13:*.mp4v=38;5;13:*.vob=38;5;13:*.qt=38;5;13:*.nuv=38;5;13:*.wmv=38;5;13:*.asf=38;5;13:*.rm=38;5;13:*.rmvb=38;5;13:*.flc=38;5;13:*.avi=38;5;13:*.fli=38;5;13:*.flv=38;5;13:*.gl=38;5;13:*.dl=38;5;13:*.xcf=38;5;13:*.xwd=38;5;13:*.yuv=38;5;13:*.cgm=38;5;13:*.emf=38;5;13:*.axv=38;5;13:*.anx=38;5;13:*.ogv=38;5;13:*.ogx=38;5;13:*.aac=38;5;45:*.au=38;5;45:*.flac=38;5;45:*.mid=38;5;45:*.midi=38;5;45:*.mka=38;5;45:*.mp3=38;5;45:*.mpc=38;5;45:*.ogg=38;5;45:*.ra=38;5;45:*.wav=38;5;45:*.axa=38;5;45:*.oga=38;5;45:*.spx=38;5;45:*.xspf=38;5;45:'
MACHTYPE=x86_64-redhat-linux-gnu
MAIL=/var/spool/mail/root
MAILCHECK=60
OLDPWD=/opt/atlassian/jira/bin
OPTERR=1
OPTIND=1
OSTYPE=linux-gnu
PATH=/usr/local/sbin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/pgsql-9.4/bin:/root/bin
PIPESTATUS=([0]="0")
PPID=2452
PROMPT_COMMAND='printf "\033]0;%s@%s:%s\007" "${USER}" "${HOSTNAME%%.*}" "${PWD/#$HOME/~}"'
PS1='[\u@\h \W]\$ '
PS2='> '
PS4='+ '
SHELL=/bin/bash
SHELLOPTS=braceexpand:emacs:hashall:histexpand:history:interactive-comments:monitor
SHLVL=1
SUDO_COMMAND=/bin/bash
SUDO_GID=0
SUDO_UID=0
SUDO_USER=root
TERM=xterm-256color
UID=0
USER=root
USERNAME=root
_=./setenv.sh
colors=/root/.dircolors
[root@JIRA-Server bin]# ./config.sh
My understanding from what I read is setenv.h should set some variables including JAVA_HOME. Note: from the above capture JAVA_HOME is set, but that was due to me setting it manually above as outlined. If I reboot, JAVA_HOME is not present. If I then run setenv.sh again JAVA_HOME is still not present, which I thought setenv.sh should be doing?
Im new to the Linux world, and im struggling to understand what is happening here.
Any help greatly appreciated.
Update:
PATH=$PATH:/opt/atlassian/jira/jre/bin[root@JIRA-Server bin]# ./config.sh
Loading application properties from /opt/atlassian/jira/atlassian-jira/WEB-INF/classes/jira-application.properties
Reading database configuration from /var/atlassian/application-data/jira/dbconfig.xml
No graphics display available; using console.
JIRA Configurator v1.1
--- Main Menu ---
[H] Configure JIRA Home
[D] Database Selection
[W] Web Server (incl. HTTP/HTTPs configuration)
[A] Advanced Settings
[S] Save and Exit
[X] Exit without Saving
Main Menu> x
This got the config.sh script to run.
Im unsure why I had to do this though? I thought the installer should set all this up. Also im still unsure why setenv.sh does not appear to be setting variables as I described above. I have no JAVA_HOME or JRE_HOME environment variables by default, and am concerned this will give issues further down the line.
Any advice welcome.
Just for anyone trying to perform the same on Ubuntu 18.04 you want to edit /etc/environment and add the /opt/atlassian/jire/jre/bin to the end, make sure to pre-pend with :
Oh and then apply the change (without rebooting)
source /etc/environment && export PATH
@James GriffinActually to solve the JAVA_PATH issue you can also add an additional line in your /etc/environment, the end result should be something like this:
PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/opt/atlassian/jira/jre/bin"
JAVA_HOME="/opt/atlassian/jira/jre/bin"
Then apply it and see if echo $JAVA_HOME shows up:
echo $JAVA_HOME
Thank you James for posting the problem and solution! I was having the same issue - it doesn't make sense why the mapping wouldn't work right out the box...but at least there is a workaround!
Thanks!
