Hello everyone,
I want to add a new context for a custom field (the field type is a select list).
I want that in some projects it has different options to choose.
So I configure special scheme contexts for every project that uses that custom field and configure options.
In the list of projects where the context is applicable I can not find my project.
What can be the reason for this and what can I do?
Thanks for your help and best regards,
Andreas
I solved it myself.
The project was already selected in another context, because I copied the Screen Scheme, and obviously Jira made itself also the entry in the already set context.
Thanks and best regards,
Andreas
Hi Andreas,
I have the same issue as above, I am unable to select my project when adding a new context. Kindly share how you resolved the issue. Thank You
Experiencing the same issue. The project is not used in the other context. Any ideas?
