Notification of issue created if not a Project Lead?
Joanna Majewska March 27, 2018
How can I get a notification of issue created if I'm not a Project Lead?
Can you set up a post function in a workflow?
Or do I need to change the notification scheme? if yes, how?
Many thanks
Joanna
What I've done is I amended the notification scheme. In create issue I've added Single user and added myself. in this way I get notified when someone create an issue.
Many thanks for your replies.
Joanna
Jose M.
March 27, 2018
I think the easiest way is indeed to adapt the notfication scheme. If you have the administration permission role you can notify all the users with that role or you can define a specific group.
Jose M.
March 27, 2018
Laurens Coppens
Hi Joanna,
It depends on the notification scheme, but normally you have a "role" called project watcher, then they should get a notification.
