×Hi there,
I have a question
How to notify Linked issue Assignee when issue resolved?
Example
- issue 10 linked to issue 9 as starts after (see image)
- When issue 9 resolved, how I can configure in Jira Administration to let issue's 10 Assignee to get email Notification?
If my question is not clear, please let me know
Thank you very much!
You would need an add-on for it like Power Scripts, Script Runner, Automation for Jira.
If you want to use the Power Scripts add-on, you could write a post function for the resolved transition with a code like this:
string[] links = allLinkedIssues(
key
"Your Link"
for (string link in links) {sendEmail(
"testFrom@cprime.com"
, {assignee}, {},
"testSubject.tpl"
"testBody.tpl"
You can find more information here:
Hi Alex,
Do you mean that I need to use Plugin like Script Runner and add more code to current Jira code as your sample script?
We have been using Scrip Runner as trial. We will process to buy it. But i am not familiar with writing source code. Could you please guide me in more detail for how to add your sample code to send notification?
Hi Anh,
Have you solved this question? I faced the same situation.
