hi,
I tried to use the Automation plug in, to set the "Sprint" field with the active sprint. (version 7.1.3).
I got this error: "No fields or field values to edit for issues (could be due to some field values not existing in a given project)"
Thanks in advance for your help.
Cheers.
Did found the root cause for this?
I am also facing the exact error when setting sprint value.
Eshwar
hello @Eshwar Palem ,
Yes. It is due to the fact that I have to mentioned which JIRA board is giving me the active sprint.
Sometimes, a JIRA project could be share by several boards... and it could be a trap for this particular field.
Cheers.
So, did you added the board field too? Where we will provide Board URL.
