I have added a custom field(single select type) and I want to link it to a specific user group.
In other words , I want to fetch custom field options from a specific user group.
Please suggest appropriate solution.
Thank You!
i think the following plugin what you are looking for
https://marketplace.atlassian.com/plugins/ru.mail.jira.plugins.userpickers
this functionality implemented on jira 6.2, check this
https://jira.atlassian.com/browse/JRA-7659
and you can download jira 6.1.6 version from here
https://marketplace.atlassian.com/plugins/ru.mail.jira.plugins.userpickers/versions
Thanks for the response!
Does Jira provide any such functionality out of the box? Beacause I have to use it with jira 6.1.6 and this plugin shows compatibility for only v 5.0 - v5.1.8.
Thanks...
Can this plugin be used to fetch option values of a custom field from some other custom/system field?
i don't think it will do and i don't have much knowldge on this plugin!!
