Problem with JIRA Time Tracker.
srinivasp
September 6, 2012
If i enter the time spent (effort) after confirming the issue, the original estimate is becoming 0.
Does anyone have a solution?
vkharisma
December 22, 2012
You may want to check your workflow configuration if you have a post function - set estimate to 0
Hope this helps!
