Hi, I develop this Custom Listener:
package com.meredith.jira.groovy import org.apache.log4j.Category import com.atlassian.jira.ComponentManager import com.atlassian.jira.bc.JiraServiceContext import com.atlassian.jira.bc.JiraServiceContextImpl import com.atlassian.jira.bc.filter.SearchRequestService import com.atlassian.jira.event.issue.AbstractIssueEventListener import com.atlassian.jira.event.issue.IssueEvent import com.atlassian.jira.event.listeners.reindex.ReindexMessageListener import com.atlassian.jira.issue.IssueManager import com.atlassian.jira.issue.MutableIssue import com.atlassian.jira.issue.fields.CustomField import com.atlassian.jira.issue.search.SearchRequest import com.atlassian.jira.issue.search.SearchResults import com.atlassian.jira.web.bean.PagerFilter import com.atlassian.jira.issue.Issue import com.atlassian.jira.issue.CustomFieldManager import com.atlassian.jira.component.ComponentAccessor class PutNoMI extends AbstractIssueEventListener { Category log = Category.getInstance(PutNoMI.class) //private static final Long FILTER_ID = 10201 ComponentManager cm = ComponentManager.getInstance() CustomFieldManager cfm = cm.getCustomFieldManager() def optionsManager = ComponentAccessor.getOptionsManager() def authenticationContext = cm.getJiraAuthenticationContext() JiraServiceContext ctx = new JiraServiceContextImpl(authenticationContext.getUser()) def searchProvider = cm.getSearchProvider() SearchRequestService searchRequestService = cm.getSearchRequestService() SearchRequest request = searchRequestService.getFilter(ctx,10201) IssueManager issueManager = cm.getIssueManager() public PutNoMI() { log.setLevel(org.apache.log4j.Level.DEBUG) log.debug "debug statements" log.info "in constructor" } @Override void workflowEvent(IssueEvent event) { MutableIssue issue = event.issue as MutableIssue CustomField workPriority = cfm.getCustomFieldObjects(issue).find {it.name == "Comment MI"} //MODIFICAT def fieldConfig = workPriority.getRelevantConfig(issue) def newValue = optionsManager.getOptions(fieldConfig)?.find{it.value == "No"} //log.info "Value to change CommentMI in next issue: ${newValue}" def results = getSearchResults(request) results.getIssues().eachWithIndex { iss , i -> issue = issueManager.getIssueObject(iss.id) log.info "Processing ${issue.key}" i += 1 def commentMI = issue.getCustomFieldValue(workPriority) log.info "Actual Value of CommentMI: ${commentMI}" log.info "GO, changin commentMI..." issue.setCustomFieldValue(workPriority, newValue) def newCurrentIssuePriority = issue.getCustomFieldValue(workPriority) log.info "CHANGED! New value of commentMI in this issue: ${newCurrentIssuePriority}" } } SearchResults getSearchResults(SearchRequest sr) { return searchProvider.search(sr.getQuery(), authenticationContext.getUser(), PagerFilter.getUnlimitedFilter()) } }
But I have problem, my logs shows that the custom Field is changed but when I enter to issue, the custom field 'Comment MI' still the same..
These are my logs:
2013-04-09 12:35:50,449 http-bio-8080-exec-7 ERROR admin 755x2398x1 ucrbou 192.94.163.146 /rest/api/2/issue/PI-1067/comment [groovy.canned.utils.ConditionUtils] javax.script.ScriptException: java.lang.NullPointerException: Cannot invoke method contains() on null object 2013-04-09 12:35:50,479 http-bio-8080-exec-7 ERROR admin 755x2398x1 ucrbou 192.94.163.146 /rest/api/2/issue/PI-1067/comment [groovy.canned.utils.ConditionUtils] javax.script.ScriptException: java.lang.NullPointerException: Cannot invoke method contains() on null object 2013-04-09 12:35:50,486 http-bio-8080-exec-7 DEBUG admin 755x2398x1 ucrbou 192.94.163.146 /rest/api/2/issue/PI-1067/comment [meredith.jira.groovy.PutNoMI] debug statements 2013-04-09 12:35:50,486 http-bio-8080-exec-7 INFO admin 755x2398x1 ucrbou 192.94.163.146 /rest/api/2/issue/PI-1067/comment [meredith.jira.groovy.PutNoMI] in constructor 2013-04-09 12:35:50,534 http-bio-8080-exec-7 INFO admin 755x2398x1 ucrbou 192.94.163.146 /rest/api/2/issue/PI-1067/comment [meredith.jira.groovy.PutNoMI] Processing PI-1067 2013-04-09 12:35:50,535 http-bio-8080-exec-7 INFO admin 755x2398x1 ucrbou 192.94.163.146 /rest/api/2/issue/PI-1067/comment [meredith.jira.groovy.PutNoMI] Actual Value of CommentMI: Yes 2013-04-09 12:35:50,535 http-bio-8080-exec-7 INFO admin 755x2398x1 ucrbou 192.94.163.146 /rest/api/2/issue/PI-1067/comment [meredith.jira.groovy.PutNoMI] GO, changin commentMI... 2013-04-09 12:35:50,535 http-bio-8080-exec-7 INFO admin 755x2398x1 ucrbou 192.94.163.146 /rest/api/2/issue/PI-1067/comment [meredith.jira.groovy.PutNoMI] CHANGED! New value of commentMI in this issue: No 2013-04-09 12:35:50,567 http-bio-8080-exec-7 INFO admin 755x2398x1 ucrbou 192.94.163.146 /rest/api/2/issue/PI-1067/comment [meredith.jira.groovy.PutNoMI] Processing PI-1066 2013-04-09 12:35:50,569 http-bio-8080-exec-7 INFO admin 755x2398x1 ucrbou 192.94.163.146 /rest/api/2/issue/PI-1067/comment [meredith.jira.groovy.PutNoMI] Actual Value of CommentMI: Yes 2013-04-09 12:35:50,569 http-bio-8080-exec-7 INFO admin 755x2398x1 ucrbou 192.94.163.146 /rest/api/2/issue/PI-1067/comment [meredith.jira.groovy.PutNoMI] GO, changin commentMI... 2013-04-09 12:35:50,569 http-bio-8080-exec-7 INFO admin 755x2398x1 ucrbou 192.94.163.146 /rest/api/2/issue/PI-1067/comment [meredith.jira.groovy.PutNoMI] CHANGED! New value of commentMI in this issue: No 2013-04-09 12:35:50,571 http-bio-8080-exec-7 INFO admin 755x2398x1 ucrbou 192.94.163.146 /rest/api/2/issue/PI-1067/comment [meredith.jira.groovy.PutNoMI] Processing PI-1062 2013-04-09 12:35:50,574 http-bio-8080-exec-7 INFO admin 755x2398x1 ucrbou 192.94.163.146 /rest/api/2/issue/PI-1067/comment [meredith.jira.groovy.PutNoMI] Actual Value of CommentMI: Yes 2013-04-09 12:35:50,574 http-bio-8080-exec-7 INFO admin 755x2398x1 ucrbou 192.94.163.146 /rest/api/2/issue/PI-1067/comment [meredith.jira.groovy.PutNoMI] GO, changin commentMI... 2013-04-09 12:35:50,574 http-bio-8080-exec-7 INFO admin 755x2398x1 ucrbou 192.94.163.146 /rest/api/2/issue/PI-1067/comment [meredith.jira.groovy.PutNoMI] CHANGED! New value of commentMI in this issue: No 2013-04-09 12:35:50,995 com.atlassian.mywork.client.reliability.DefaultUnreliableWorker:thread-1 WARN admin 629x57x1 boasfh 192.94.163.146 /secure/admin/util/JellyRunner.jspa [apache.commons.httpclient.HttpMethodBase] Going to buffer response body of large or unknown size. Using getResponseBodyAsStream instead is recommended. 2013-04-09 12:35:51,825 com.atlassian.mywork.client.reliability.DefaultUnreliableWorker:thread-1 WARN support 629x57x1 boasfh 192.94.163.146 /secure/admin/util/JellyRunner.jspa [apache.commons.httpclient.HttpMethodBase] Going to buffer response body of large or unknown size. Using getResponseBodyAsStream instead is recommended.
Any idea of my problem?
Thanks for answer guys!
I share my code for anyone have the same problem, and this is solution or you want to copy to antoher implementation :
package com.meredith.jira.groovy import org.apache.log4j.Category import com.atlassian.jira.ComponentManager import com.atlassian.jira.bc.JiraServiceContext import com.atlassian.jira.bc.JiraServiceContextImpl import com.atlassian.jira.bc.filter.SearchRequestService import com.atlassian.jira.event.issue.AbstractIssueEventListener import com.atlassian.jira.event.issue.IssueEvent import com.atlassian.jira.issue.IssueManager import com.atlassian.jira.issue.MutableIssue import com.atlassian.jira.issue.fields.CustomField import com.atlassian.jira.issue.search.SearchRequest import com.atlassian.jira.issue.search.SearchResults import com.atlassian.jira.web.bean.PagerFilter import com.atlassian.jira.issue.Issue import com.atlassian.jira.issue.CustomFieldManager import com.atlassian.jira.component.ComponentAccessor import com.atlassian.jira.workflow.WorkflowUtil import com.opensymphony.workflow.WorkflowContext import com.atlassian.jira.event.type.EventDispatchOption class PutNoMI extends AbstractIssueEventListener { Category log = Category.getInstance(PutNoMI.class) //private static final Long FILTER_ID = 10201 ComponentManager cm = ComponentManager.getInstance() def userManager = cm.getUserUtil() def userId = userManager.getUser("admin") CustomFieldManager cfm = cm.getCustomFieldManager() def optionsManager = ComponentAccessor.getOptionsManager() def authenticationContext = cm.getJiraAuthenticationContext() JiraServiceContext ctx = new JiraServiceContextImpl(authenticationContext.getUser()) def searchProvider = cm.getSearchProvider() SearchRequestService searchRequestService = cm.getSearchRequestService() SearchRequest request = searchRequestService.getFilter(ctx,10201) IssueManager issueManager = cm.getIssueManager() public PutNoMI() { log.setLevel(org.apache.log4j.Level.DEBUG) log.debug "debug statements" log.info "in constructor" } @Override void workflowEvent(IssueEvent event) { MutableIssue issue = event.issue as MutableIssue CustomField workPriority = cfm.getCustomFieldObjects(issue).find {it.name == "Comment MI"} //MODIFICAT def fieldConfig = workPriority.getRelevantConfig(issue) def newValue = optionsManager.getOptions(fieldConfig)?.find{it.value == "No"} //log.info "Value to change CommentMI in next issue: ${newValue}" def results = getSearchResults(request) results.getIssues().eachWithIndex { iss , i -> issue = issueManager.getIssueObject(iss.id) log.info "Processing ${issue.key}" i += 1 def commentMI = issue.getCustomFieldValue(workPriority) log.info "Actual Value of CommentMI: ${commentMI}" log.info "GO, changin commentMI..." issue.setCustomFieldValue(workPriority, newValue) def newCurrentIssuePriority = issue.getCustomFieldValue(workPriority) log.info "CHANGED! New value of commentMI in this issue: ${newCurrentIssuePriority}" issueManager.updateIssue(userId, issue, EventDispatchOption.ISSUE_UPDATED, false) } } SearchResults getSearchResults(SearchRequest sr) { return searchProvider.search(sr.getQuery(), authenticationContext.getUser(), PagerFilter.getUnlimitedFilter()) } }
You need to do more than issue.setCustomFieldValue()... look into using the IssueService.
If you are not setting the field value through workflow for current ticket, then you will have to Update the issue once you have set some field's value in a request.
issueManager.updateIssue(currentUser, issue, EventDispatchOption.ISSUE_UPDATED, true);
Thanks! Works for me :)
