Hi there!
I wanna change the Screen Scheme of a project I've already created. Currently, "Default Issue Type Screen Scheme" is assigned to my project and an error page is shown relating to a null pointer exception when clicking the link. Does anyone have an idea about the reasons of this problem?
Thank you in advance.
@Amadeo CuadradoDon't go via this link, go to Jira admin button navigate to Screens under screens check issue type screen scheme if the defualt issue type screen scheme is there, then make a copy, associate it to a project, check and see whether it works or not , before we dig into logs.
Thank you for your fast responses.
I’ve tried what you said, but I'm still in problems. I've just taken the following steps:
I’ve just made a copy of the item as you asked me for just to check if that was possible and I succeeded. After that you’re asking me to associate the copy to my project, but the only way I know to do it is by using the problematic link in the configuration page of the project I’d like to set up. Is there any other way to perform this action?
Anyway, it doesn’t matter if I try to change the screen scheme of any other project with different screens schemes configured… does it rings a bell with you?
What I wish is configure the New Esquema de Screens Ágil for this project instead of the default one:
Thank you so much for your time and help!
Hi! Here it is the logs extraction. If you need more information, please just tell me.
Thank you in advance!
2018-05-28 10:22:54,810 http-8080-8 ERROR [500ErrorPage.jsp] Exception caught in 500 page null
java.lang.NullPointerException
at com.atlassian.jira.issue.fields.screen.issuetype.DefaultProjectIssueTypeScreenSchemeHelper.getProjectsForFieldScreenSchemes(DefaultProjectIssueTypeScreenSchemeHelper.java:71)
at sun.reflect.GeneratedMethodAccessor2494.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at com.atlassian.multitenant.impl.MultiTenantComponentFactoryImpl$AbstractMultiTenantAwareInvocationHandler.invokeInternal(MultiTenantComponentFactoryImpl.java:181)
at com.atlassian.multitenant.impl.MultiTenantComponentFactoryImpl$MultiTenantAwareInvocationHandler.invoke(MultiTenantComponentFactoryImpl.java:211)
at $Proxy372.getProjectsForFieldScreenSchemes(Unknown Source)
at com.atlassian.plugin.osgi.hostcomponents.impl.DefaultComponentRegistrar$ContextClassLoaderSettingInvocationHandler.invoke(DefaultComponentRegistrar.java:129)
at com.atlassian.plugin.osgi.bridge.external.HostComponentFactoryBean$DynamicServiceInvocationHandler.invoke(HostComponentFactoryBean.java:154)
at com.atlassian.jira.projectconfig.contextproviders.ProjectScreensContextProvider.getScreenSchemes(ProjectScreensContextProvider.java:119)
at com.atlassian.jira.projectconfig.contextproviders.ProjectScreensContextProvider.getContextMap(ProjectScreensContextProvider.java:80)
at com.atlassian.jira.plugin.webfragment.CacheableContextProviderDecorator.initContextMap(CacheableContextProviderDecorator.java:70)
at com.atlassian.jira.plugin.webfragment.CacheableContextProviderDecorator.getContextMap(CacheableContextProviderDecorator.java:46)
at com.atlassian.plugin.web.descriptors.DefaultWebPanelModuleDescriptor$ContextAwareWebPanel.getHtml(DefaultWebPanelModuleDescriptor.java:141)
at com.atlassian.jira.projectconfig.tab.WebPanelTab.getTab(WebPanelTab.java:75)
at com.atlassian.jira.projectconfig.servlet.PanelServlet.outputTab(PanelServlet.java:163)
at com.atlassian.jira.projectconfig.servlet.PanelServlet.doGet(PanelServlet.java:136)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at com.atlassian.plugin.servlet.DelegatingPluginServlet.service(DelegatingPluginServlet.java:42)
at com.atlassian.plugin.servlet.ServletModuleContainerServlet.service(ServletModuleContainerServlet.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(ChainedFilterStepRunner.java:74)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at com.atlassian.core.filters.HeaderSanitisingFilter.doFilter(HeaderSanitisingFilter.java:44)
at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46)
at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66)
at com.atlassian.applinks.core.rest.context.ContextFilter.doFilter(ContextFilter.java:25)
at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74)
at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42)
at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77)
at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63)
at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.executeRequest(AccessLogFilter.java:103)
at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.doFilter(AccessLogFilter.java:87)
at com.atlassian.jira.security.xsrf.XsrfTokenAdditionRequestFilter.doFilter(XsrfTokenAdditionRequestFilter.java:54)
at com.opensymphony.sitemesh.webapp.SiteMeshFilter.obtainContent(SiteMeshFilter.java:129)
at com.opensymphony.sitemesh.webapp.SiteMeshFilter.doFilter(SiteMeshFilter.java:77)
at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:211)
at com.atlassian.security.auth.trustedapps.filter.TrustedApplicationsFilter.doFilter(TrustedApplicationsFilter.java:98)
at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:150)
at com.atlassian.jira.web.filters.JiraLoginFilter.doFilter(JiraLoginFilter.java:70)
at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:71)
at com.atlassian.util.profiling.filters.ProfilingFilter.doFilter(ProfilingFilter.java:108)
at com.atlassian.jira.web.filters.JIRAProfilingFilter.doFilter(JIRAProfilingFilter.java:19)
at com.atlassian.johnson.filters.AbstractJohnsonFilter.doFilter(AbstractJohnsonFilter.java:71)
at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:350)
at com.atlassian.gzipfilter.GzipFilter.doFilterInternal(GzipFilter.java:81)
at com.atlassian.gzipfilter.GzipFilter.doFilter(GzipFilter.java:51)
at com.sysbliss.jira.plugins.workflow.servlet.JWDSendRedirectFilter.doFilter(JWDSendRedirectFilter.java:25)
at com.atlassian.core.filters.cache.AbstractCachingFilter.doFilter(AbstractCachingFilter.java:33)
at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31)
at com.atlassian.core.filters.encoding.AbstractEncodingFilter.doFilter(AbstractEncodingFilter.java:41)
at com.atlassian.jira.web.filters.PathMatchingEncodingFilter.doFilter(PathMatchingEncodingFilter.java:49)
at com.atlassian.jira.web.monitor.ActiveRequestsFilter$PassToChainFilterFunc.doFilter(ActiveRequestsFilter.java:346)
at com.atlassian.jira.web.monitor.ActiveRequestsFilter$DebugLogFilterFunc.doFilter(ActiveRequestsFilter.java:463)
at com.atlassian.jira.web.monitor.ActiveRequestsFilter.doFilter(ActiveRequestsFilter.java:173)
at com.atlassian.jira.startup.JiraStartupChecklistFilter.doFilter(JiraStartupChecklistFilter.java:75)
at com.atlassian.multitenant.servlet.MultiTenantServletFilter.doFilter(MultiTenantServletFilter.java:91)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:852)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
at java.lang.Thread.run(Thread.java:619)
@Amadeo CuadradoThis likely the reason that the default issue type with you have set for the default issue type scheme is missing/deleted.
Please go to the default issue type scheme and manually change default issue type and save it and see whether it works! if not then please follow this documentation below and try to fix it.
Best !
Mmmmm... I tried, but still in problems. Anyways I'd like to ask you one more time.
I understood that I should edit the “Default Issue Type Scheme” and check if there was any “Default Issue Type” configured, so I went to Issues > Issue Type…
Then I selected the “Issue Type Scheme” tab and clicked on Edit link:
That took me to this page where we can see than the Default Issue Type Scheme is associated to two projects (OficinaCalidad and iJimena) and the Default Issue Type is set up to Bug:
As I understood about your comment, maybe there was not option selected in that combo, isn’t it? This doesn’t happened with this Issue Type Scheme but I checked others and some of them has no Default Issue Type configured, but it seems to be quite usual, should I be worried because of that? (Ninguno = None)
I must say that both projects associated to the Default Issue Type Scheme (OficinaCalidad and iJimena) are not actually in use. In fact we have another problem whit that, because OficinaCalidad was created just to test something and when we tried to delete it, we had another unhandled error. The project is not been listing on the Projects menu anymore, but you can access by URL and a null pointer exception is thrown again. Log:
at com.atlassian.jira.projectconfig.contextproviders.ScreensSummaryPanelContextProvider$SimpleIssueTypeScreenScheme.<init>(ScreensSummaryPanelContextProvider.java:217)
at com.atlassian.jira.projectconfig.contextproviders.ScreensSummaryPanelContextProvider.getContextMap(ScreensSummaryPanelContextProvider.java:59)
at com.atlassian.plugin.web.model.AbstractWebItem.getContextMap(AbstractWebItem.java:30)
at com.atlassian.plugin.web.model.DefaultWebLabel.getDisplayableLabel(DefaultWebLabel.java:55)
at com.atlassian.jira.projectconfig.contextproviders.SummaryContextProvider.getPanelFromDescriptor(SummaryContextProvider.java:129)
at com.atlassian.jira.projectconfig.contextproviders.SummaryContextProvider.getPanels(SummaryContextProvider.java:114)
at com.atlassian.jira.projectconfig.contextproviders.SummaryContextProvider.getContextMap(SummaryContextProvider.java:92)
I suppose than both problems are related and if we can fix the first one, maybe the other can be solved as well…
@Amadeo CuadradoThese issue types which you set as default do you have them in you Jira instance? if yes then you need to follow documentation which i have already send to you.
I only have Bug, Ninguna is not listed because I suppose it's a default Jira value (in spanish because of the region configuration)… you know, if you don’t choose any option, Ninguna could be displayed just because something must be displayed by the system.
Should I change than value for another type? Sorry for asking any little question (in fact, I sound very stupid to myself), but we inherited this jira instance from a previous working group (which there is no possibility to ask for help) and it’s customized, so I don’t know if it could be dangerous changing this configuration...
Once again check issue types list them for me.
In default issue type scheme set the default issue type to subtask can you do this from the combo ?
then try again to go via that link that you get error
Best
Sure. Attached image shows you which Issues Types are used for each Issues Type Schemes. The left column contains every issue types defined in this jira instance. As you can notice:
@Amadeo CuadradoInteresting so what happens when go to default issue type scheme set the default issue type to subtask or another ?
I've just tried and it's set correctly. Then I try to access to any project and I click in the problematic link, but the NullPointer is thrown again
@Amadeo CuadradoSo this could be a Bug in your Jira instace please create a support request to atlassian support with support zip file by going as Admin to system >support tools > create support zip
create request here https://support.atlassian.com/contact/#/
Good luck.
Thank you so much Moses, I'll also try to perform a reindex action when the service can be stopped for some hours.
Thank you for your time and support!
Yeah! We got it! Finally the problem was on the reindexing process. We run it but it knocked down the server in a first attempt because of an outOfMemory error… and in addition, we were not able to find issues by queries… Then we increased the memory for Jira and the reindexation worked so we could delete the problematic project, set a new Screen Scheme and find the issues again.
One more time, thank you for your patience!
@Amadeo CuadradoI am happy that finally issue is resolved :) Vote!/accept solution i am sure if any one will come across this issue, they should be able to use solution :)
Best!
Sorry, it's mi very first time and didn't know I could attach images.
This is the point:
It's at the bottom of the administration project page.
Thanks!
HI @Amadeo Cuadrado,
As u mentioned you only have created this project and the default Issue type screen scheme has been associated with this project so now you wanna change the issue type scheme so just click on the Default issue type Screen scheme and it will redirect you to a new page and select the screen scheme that you want to apply.
If the same error will persist again then refresh and try or else see the log file where you will get the exact reason behind this error.
Yeah, the exception is thrown just in this point, so I can't reach the page in which I should change the scheme, that's the problem. I've asked for the log to the System group, but I guess it'll be hard to understand it.
If just anyone had gone through the same problem before and could tell me what to do to resolve it, it'd be perfect, but I'll include the log information when I get it, just in case...
hI @Amadeo Cuadrado,
Could you please let us know which link you have been clicked hence you are getting Null pointer exception.
