Hello community, thanks for reading my issue. I'm new to Jira and I'm trying to get a custom object field to populate only with the company to which the user logged into the portal belongs.
My objects are called "User" and have the attributes Name, Email, and Company (of type object).
"Company" and has the attribute Name.
Create a user object that assigns a company to it.
What AQL should I use? Thanks!
Hi @Emmanuel Muñoz , interesting use-case! Can you describe some more where the company value would be determined automatically from?
Any screenshots or sample process flows would help as well!
