I am looking at the different options available under project automation, but am having trouble finding how to set the logic - if Field Change Type is set to Emergency upon creation, I want that ticket to only be able to follow a certain pathway through the overall workflow, so basically I want to be able to provide the system with the pathway so if it transitions to A then only C and D are available next, then if c or D, then F, etc. How would I do this?
you should take a look at:
@carly_noreen you can use "Conditions" on workflow, or you can use the "If/Else block" condition on automation.
However if you want a suggestion, i can suggest to use the "JMWE" add-on.
You can create conditions with more conditions on workflow
I hope I helped you.
If this post was helpful, mark it as Accepted solutions, so you can help others who may have the same difficulties.
If your question has not been resolved, please post again with more details.
