Automation
On Creation of a work item, which I assume is a Change task, if the Change Request Type is one of the selected ones, then assign the ticket to a specific user.
I am getting "The following work items did not match the condition:" I dont know what work item it is not matching on, how can I determine what is wrong?
Hi @alan.kehoe -- Welcome to the Atlassian Community!
Please review the audit log details for the rule execution, and expand all the details with the arrows at the right side of the log. That will show which rule steps ran and the work items that did / did not meet the conditions.
You could also add Log actions to your rule before the conditions to see what values the rule "sees" in the fields: https://support.atlassian.com/cloud-automation/docs/jira-automation-actions/#Log-action
If that does not help, please post the following to provide more context for the community to offer suggestions:
Based upon your rule image, it uses the Work Item Created trigger...
That trigger (among others) has a "racetrack error" where the rule can start running before all of the data is available to the rule. This can cause errors or conditions not matching as expected.
The mitigation / fix for this is to always add the Re-fetch Work Item Data immediately after the Work Item Created trigger. This will slow the rule slightly and reload the data before the steps proceed.
Please add that action and re-test your rule.
You are a life saver the re-fetch worked like a charm. Good to know the rule was completing before the ticket had fully populated all the fields.
Awesome; I am glad to learn that change solved it!
Ah yes! So that means that your work item BAC-23289 didn't meet the requirements set in the automation to run. This means that BAC-23289's:
Based on the screenshot, I have a hunch BAC-23289 is a different issue type since the icon on the screenshots don't match (ie in the audit log, the work item's icon is an orange lock icon, but in the automation, the "Change" issue type has a purple double arrow icon.
Hope this helps - happy automating!
Apologies, I didnt pick a ticket that met the criteria. I will create a new ticket today and send a screenshot
Also getting this when I click on Change Type
"No Matches found. Create a new request type with the Change Work type."
Hi @alan.kehoe
Please provide more details on the project type and screenshot of the error message you are getting?
Hmm, like the other folks mentioned, it’s hard to know what the automation problem is without seeing a screenshot. Giving it a shot in the dark:
Because the error message you received is regarding the condition, that would likely be that the condition set 1) doesn’t exist, 2) no action needed, 3) conditions may be set to exclude instead of include.
Upload a screenshot and it looks like there’s an army of folks willing to dig in deeper!
Hi @alan.kehoe,
In order to help it would be useful if you posted screenshots of the rule and the audit log. Without those it is really hard to tell you what is wrong with the automation.
