×Hi guys, I am trying to create an automation that does the following -
Let's say there is 20 components held on the (Compass Components List) -
I am trying to make a manual trigger automation that automatically calculates the total score of their risk based on the fact that no matter how many of those "Components" of a specific risk level are added, their value is only considered once.
So High Risk + High Risk + Medium Risk = 15 Points not 25.
So far, I've encountered a stumbling block in attempting to use an Automation to calculate this score -
If I use branching and set up an IF Condition saying if High Risk Component is selected, then create a variable called HighRiskScore with score 10. And then a second branch saying if Medium Risk Component is selected, then create a second variable with the score of 5. And ask them to output at every branch, I get a total value of 0. Meaning that when I then try to calculate the total score, I also get 0.
If I use If / Else conditions, I block out the possibility for it to advance down the chain of IFs by having the first condition met. And if I use just an IF condition followed by action, followed by a next IF, it skips all the points underneath the original IF.
Does anyone know what I can do in this situation? I've attached a crudely drawn diagram of how I want it to act below.
For a question like this, context is important for the community to help. Please post the following:
Until we see those...
How are you associating a risk indicator / score to the Compass Components?
Let's assume you are using the component's name to identify "risk level" and then using that to map to the scoring. If so, there are at least four ways to do this:
Hey @Tyler Cassar
This sounds like a classic case where automation starts to hit its limits, especially with conditional logic and branching.
If you're open to trying an app, you might find Risk Radar helpful.
It’s a lightweight tool that lets you assign risk levels (e.g., High/Medium/Low) and automatically calculates a risk score per issue without needing to set up complex automation rules.
Each unique component type (or custom field value) is only counted once in the score logic, just like what you're aiming for.
It might save you time and give your team a consistent, visual way to manage and communicate risk.
Hope that helps!
Hi @Maksym Babenko_TypeSwitch_
As a reminder...when recommending a marketplace vendor product, please ensure you disclose your affiliation to that vendor in your post wording, and not just in your profile name / badge. For more information about this, please see:
Atlassian Partners - Rules of Engagement
Could you use "IF ... ELSE IF" instead of "IF ... ELSE"? That way, the rule should keep going since the conditions are reevaluated at each "ELSE IF"-node.
Underneath an existing IF condition, click on "ELSE". If you add at least one condition in the ELSE node, the 'ELSE' should turn into 'ELSE IF'. Otherwise it remains an unconditional 'ELSE'.
Wouldn't that still lead to conditionals being missed?
Wouldn't that mean if I had a High Risk + a Medium Risk, since there was an action taken on High Risk, it would just auto ignore the Medium Risk?
Or do I need to build it in a IF High Risk + Medium Risk + Low Risk, and all the combinations combined?
You certainly have a point there. And right now I cannot think of something more elegant than going through several combinations. You could use the 'contains' or 'contains none of' condition for the 'Components' field, or work with the 'IN' operator in JQL: 'component in (value 1, value 2, ...), or the NOT IN or the CONTAINS or the DOES NOT CONTAIN operators. Sorry. If I can think of something more elegant, I'll add it here.
One more idea: you could create three rules instead of one, and have the first one (the manually triggered one) do something that then triggers the other two (like modifying a field, perhaps a hidden one), each rule checking only for components of one type. But that will cost you three units off your rule count, which may be limited depending on you Jira license plan.
I actually came to the same conclusion to get the final risk scoring funnily enough.
