Hello everyone,
Could someone help me with this one ?
I'm trying to update a custom multi group picker from a custon single group picker.
Currently I'm trying this one :
{ "update": {
"customfield_11646": [{ "add": { "name": "{{triggerissue.customfield_11647.name}}" }
It works great if I hard code the group name :
[{ "add": { "name": "my-group-name" }
But I need this one to be dynamic.
I also tried to display my {{triggerissue.customfield_11647.name}} in a log work, but it reamains empty.
Thank you,
Nicolas
Hi Nicolas,
I just used the actual field names and it worked fine.
"update": {
"Approver groups": [{
"add": { "name": "{{triggerIssue.Group Single Picker}}" }
Remember also that the smart values are case sensitive so it is triggerIssue and not triggerissue. Not sure if that was the difference or not.
Hi John,
Thank you so much! It works perfectly!
Is there any chance to update the Approver group with another Group Multi ? Or is it limited to Group Single Picker ?
Thanks !
It should work - the problem is if there are multiple groups already loaded in the Group Multi - but it should hopefully copy all of them.
In my case I'd like to use only one multi group field, let's say "GroupMulti". With below scenario :
1. When an epic is created "GroupMulti" is set with the reporter's group (only one value)
2. When this epic is linked (using parent field) to an initiative, the "GroupMulti" field at Initiative level is automatically updated with the value of the "GroupMulti" at epic level.
It means that each time a new epic is linked to this initiative, a new "GroupMulti" value is added.
3. When an epic is unlinked, its value should be removed from the "GroupMulti" field at initiative level.
As i want to update the "GroupMulti" from itself at another level, I'm not sure it is possible.
This is why I tried it with 2 group fields in my first request.
@John Funk any idea ?
Thank you
Try to replace the name with value
As you are now referencing the CF field name and not the value set in the field
Hi @Marc - Devoteam ,
Do you talk about this "name" ?
"update": {
"add": { "name": "{{triggerissue.customfield_11647.value}}" }
If so, it doesn't work either :(
Does the log action on {{triggerissue.customfield_11647.value}} and or {{triggerissue.customfield_11647.name}}
Can you does this for the Branch, does this give a result?
