Automation copy from parent issue does not work
Christian Völker June 7, 2023
I´m trying to automate that 3 costum fields get filled automatically, when a new issue is created and the parent link is know. Everything what I tried doesn´t work it always result in the information "Can´t find issue to copy".  Even my parent if cause brings the result that the parent link is there. See picture below
Andras M
Hi, would it be the problem, that the rule has no access (scope) to the parent issue?
If this is a Project rule and the parent issue is in another project, I guess, JIRA cannot "clone" the FixVersion value from it... so the rule should be set as Global rule.
You need to make the rule multi-project or global.
But this is just a guess.
Manoj Gangwar
Hi @Christian Völker ,
Click on the edit issue fields>>then after adding the fields>>click on three dots>>select copy data from parent issue.
@Manoj Gangwar
I did this already. See picture below
So there needs to be another reason. Hope anybody could help me.
Manoj Gangwar
Can you try to use the Branch rule/related issue > Stories(other issues in epic) ?
Like Christian Völker likes this
do you mean like this? Or should i put it somewhere else?
John Funk
Hi @Christian Völker  - Can you share the details of the Edit issue fields action?
Also, you need to move those bottom 4 objects under the Branch - right now they are at the same level.
Christian Völker June 8, 2023
Hi @John Funk
see the issue field action
As well if have adjusted the branch now:
But still it doesn´t work
John Funk
Sorry - I missed that above. But if you move those 4 items under the branch, that should fix it for you.
See above. Still it doesn´t work :(
This is the message I see in the audit
@John Funk
Maybe i want to copy that information not from an Epic. I want to copy it from an Initiative to an Epic. Maybe this helps for providing me the correct hint :)
John Funk
So what exactly are you trying to accomplish?
Christian Völker June 12, 2023
@John Funk
I want to copy information from 3 fields of the parent issues when parent Link is set. So that the information don´t need to be filled manually into the created Epic.
John Funk
You wouldn't use Parent Link - that is for the parents of Epics.
 But I can see the parent Link field in the parent issue
John Funk
What is the issue type for IT-1362? And what is the issue type that has that value for that field?
The issue type of IT-1362 we name individual Demand it is a standard type. And the issue type where the value for that field is Epic. Our project hierachy is Demand-->Epic-->Story-->Sub-Task
John Funk
Okay, but it looks like you are missing apples and oranges to me. Parent Link would be used on an Epic to show the Demand parent for the Epic.
Epic Link would be used on a Story to show the Epic parent. You can't use a single rule to get both of those for a single issue.
@John Funk
I´m now confused. :( I never want to use the Epic Link and I don´t need it.
What I want is that 3 fields of a created epic will be filled automatically when the parent Link in the Epic is set.
And this is with the mentioned automation not working, because I always receive the information "Can´t find issue to copy" even, when the check for parent link passed.
John Funk
Thanks for the clarification. Maybe I am missing something or making it too simple, but what about something like below?
