Hello, I have a problem where I'm trying to create a Global Automation for multiple Projects. Even in a Company Managed Board it seems like the Transition to ''Doing'' does not work properly despite the Audit Log saying that it worked and it just ends up in the Backlog. I Also tried to create a Workaround using Components inside the projects that transitions all issues that have a specific Component assigned to it, but it doesn't even recognize the Component despite it being there.
Yeah it's normal, it misses a branch in your rule.
after the ticket creation, you need to add a branch "For : last created ticket" then the rule can realize the transition.
