I'm trying to add automation in my team's project (company-managed project) to flag issues when they are edited (in particular when they are added to a particular set of sprints) to flag them if there is data missing in them.
So my workflow is essentially:
- IF the issue is added to sprint X
- IF it's missing a label Y, flag it
- ELSE if it's missing a custom field Z, flag it
- ELSE unset the flag
The idea being that the issue will show clearly in the board as being incomplete.
I tried a manual rule as a starting point:
but I keep getting the following error when I run it:
Hi @Fabre Lambeau welcome to the Atlassian Community!
I just created an automation rule on my own site and it works.
Can you (or a Jira admin) check if you have a custom field with the same name 'Flagged' (type Checkboxes)?
