Automation for Jira: Transition to previous state
Sinio, Paul Andrew April 11, 2021
Hi Atlassian,
While AUT-47  is still not yet solved, may we ask for clarification on the workaround below especially on what is meant by "Transition action" below.  I tried to look at the action "Transition Issue"  but i don't think the workaround is referring to that.  Thank you
You could use a rule like this:
  • Trigger: Field value changed with status
  • Edit issue and set the 'Previous status' field to  {{fieldChange.from}}
Then you could transition to {{issue.Previous status}} using the 'Transition action'.
5 votes
Marco Brundel
April 12, 2021
Hi @Sinio, Paul Andrew ,
In Transition issue is it possible to put smart value.
Is this what you are looking for?
Regards, Marco
Sinio, Paul Andrew April 12, 2021
Thank you, @Marco Brundel!  I didn't know you can type smart values there
Like Marco Brundel likes this
Walker White
This works really well as a means to support transitioning to previous status.  However, when you make the custom field, do NOT use "Number" as the type.  It will convert your status ID from 3 to 3.0, and it wont work.  Using a text field works however.
Hubert Bartkowiak June 8, 2022
@Marco Brundel I've tried to use it, but automation failed with:
Destination status could not be resolved. If using a smart-value ensure this resolves to a numeric status ID or untranslated name for issues (with current status):
Is your string correct?
Marco Brundel
June 9, 2022
Hi @Hubert Bartkowiak
is correct in my opinion.
I don't know why the message "Destination status could not be resolved" follows and how you can solve this.
I can see that in this and this question it is also about this message. Maybe you'll find a solution there.
Good luck and greetings, Marco
Walker White
@Hubert Bartkowiak Per my reply above, while it has been some time since I had found my original fix, I believe I recall the symptom being "Destination status could not be resolved".
Can you confirm the smart value you are using is defined as text, like this:
Also, I think I recall that if you have already made the field as a Number type, you cannot change it.  You have to delete the field then re-create it.
Ivan Ferreira
I had to do this and I also had the "Destination status could not be resolved" even if the "Previous status" field was type text.
I solved the issue by creating a variable like this:
Then I used the variable as the transition status:
Like # people like this
Customer Resolution
August 5, 2024
Need help. my workflow look like this. and i want create automation for :
  • Trigger: Schedule
  • Action 1: Transition from any status to status "ON HOLD"
  • Action 2: Transition back from status "ON HOLD" to the previous status (dynamic) immediately.
    My question :
  • Do I still need a custom field 'Previous status'?
  • What does the smart value syntax look like for my variable?
