Automation made to calculate total project hours via Atlassian Knowledge Article not working
Faizan Iftikhar
Dear Members,
Good Day!!
I have made rule with the help of Knowledge Article but not working, PFB link.
Have converted 99 Hrs. to seconds but the condition not matching. PFB screenshot... Need your input to settle it, please. Using Jira Service Management-SAAS
https://confluence.atlassian.com/jirakb/how-to-get-total-time-logged-into-an-issue-using-automation-for-jira-1115672355.html
Bill Sheboy
September 22, 2022
Hi @Faizan Iftikhar
What does not work as you expect?  For example, if you write that smart value to the log before the condition test, does it contain a value greater than you expect?
I tried this and it worked for me.
Faizan Iftikhar
Hi @Bill Sheboy
Thanks for your reply...
Objective:
When project crossed hours limit email generated
Problem facing:
Have set rule limit of 99 hours in seconds, have tested the rule by adding hours in project but it is not generating email notification . PFB snap for reference
Bill Sheboy
September 23, 2022
That is curious...
Would you please post an image of the details of the Advance Compare Condition?
And, perhaps add a statement before the condition to write to the audit log the sum value: {{triggerIssue.worklog.timeSpentSeconds.sum}}
Faizan Iftikhar
hi @Bill Sheboy
Thanks for reply..
Sure, PFB snap of condition. have already added above mentioned condition in Advance compare...
BR,
M Faizan
Faizan Iftikhar
Hi @Bill Sheboy
Stay Safe!!
Have checked thoroughly and came to know that this statement is precisely for issue exceed limit only i.e. If issue exceeds hours limit then fire an email.
I am looking for, If hours of particular Project is exceeds limit then intimate via email.
Can you please help me out against hours exceeds limit then shoot an email.
Thanks in advance.
BR,
M Faizan
Faizan Iftikhar
@Manon Soubies-Camy  : Please help to find solution, that would be Great!!
" If hours of particular Project is exceeds limit then intimate via email."
Bill Sheboy
September 26, 2022
As you want to find this for the entire project, not for one issue, I suggest trying this:
  • write a JQL statement to find the issues you want to check/sum up
  • change your rule trigger to scheduled and run the rule periodically, such as once per day
  • instead of using one issue, use the Lookup Issues action with your JQL
  • then test the value using the following:
{{lookupIssues.worklog.timeSpentSeconds.sum}}
Faizan Iftikhar
Hi @Bill Sheboy
Appreciate your reply...
I hope, have incorporated correctly as Automation is not working.
Bill Sheboy
September 27, 2022
Two changes to make: remove the JQL from the scheduled trigger, and add a Lookup Issues action to use that JQL before your condition test.
Scheduled triggers may be used with or without JQL to gather issues.  For your use case, we want "no JQL" so the lookup can handle the issues.
Faizan Iftikhar
Thanks for reply @Bill Sheboy
if i am removing JQL form the scheduler it ended with error PFB.
Bill Sheboy
September 28, 2022
Did you also add the lookup issues action, as I cannot see the remainder of your rule.
That error seems to indicate that is not present yet.  Please see my earlier responses for details.  Thanks!
Like Faizan Iftikhar likes this
Faizan Iftikhar
thanks for connecting @Bill Sheboy
Sharing snap , hope it covers the whole scenario
Bill Sheboy
September 30, 2022
Please modify the rule like this to access the issue data...
  • trigger: your scheduled trigger
  • action: lookup issues with the JQL to find them
  • advanced compare condition: your test on the worklog from the lookup
Faizan Iftikhar
Hi @Bill Sheboy
Truly appreciate your time and patience...
  1. I have put as lookup issue with JQL and it ended with no error PFB snap, thanks
  2. Now the Problem is in Audit log it shows success but no action performed, The threshold to raise trigger is 1 hour which is not working
  3. When project hours reached to 1 hour then send mail
POINT# 2
BR,
M Faizan
Bill Sheboy
October 3, 2022
Two things to check:
Try running that JQL manually with advanced issue search (outside of the rule) to confirm it returns all of the issues you expect.
Next in the rule, after the Lookup Issues action, write the value for the sum of the time to the audit log.  Does it match what you expect for those issues?
Faizan Iftikhar
Hi @Bill Sheboy
Thanks for reply...
Point #1 : It is also running in other Rule and works fine. If I Validate query it shows correct number of issues
Point #2: Can you please elaborate " write the value for the sum of the time to the audit log "
Appreciate your time , thanks
BR,
M Faizan
Bill Sheboy
October 5, 2022
After the lookup issues action, add a write to the audit log to check the value:
