Hi I'm trying to set up a trigger to close my epic, but seems but found this issue
"No transitions found for user. Ensure that the rule actor has permission (including issue security levels) to see issue and perform transitions."
I'm using a different workflow for my epic and stories / task. is it because of that? or did I missed out something else.
thanks
Hi Fuadilah - Welcome to the Atlassian Community!
It depends on your workflow for the Epic issue type. What status are you moving from and to which status are you going? Are their Conditions or Validators on the transition to that status that might be preventing the transition?
Hi John,
The epic is using standard workflow, for stories / task / sub task, I create a new workflow for them.
for the epic I want to trigger status changes from "To Do" to "In progress" if one of the task status is transition to "In progress" status (but I create new label for this status, lets say "Development in Progress")
It is not matching the Condition where you are checking that the Stories in the Epic are in the To Do status. That is why it is failing. It's making sure that ALL stories are in the In Progress status. Is that your intent?
my intention is if one of the stories transition to in progress then epic status also will be move from "to do" to In progress.
Let say I have 3 stories in "to do" status, then one of it transition to "in progress" then it will change the epic status from "to do" to "in progress" as well
'Then you just need to change the Condition for the check on the stories. Make sure you use the Some match specific JQL option.
Thanks, I'll try your suggestion, I'll be back for update.
thanks for the help!
It worked out fine, the issue is on the status before I put "To Do" then I change it to "TO DO" all capital, and it worked.
so the status is should be in all caps. and the actor need to have permission to do the transition.
Hello @Fuadilah Mulyadhien
Welcome to the Atlassian community!
Please show us your full Automation Rule, and show us the details from the Rule Audit Log for an execution where this error occurred.
Who is specified as the Actor on the Rule Details page?
Does that user have permissions in the project where the Epic exists?
What was the status of the Epic that was trying to be changed when the rule executed and failed? In the workflow applied to the Epic is there a transition from that status to the one you were attempting to select in the rule?
- The epic is still under To Do, I want to move it to "In Progress"
- The user have permission, (I'm the admin in the project)
Hi @Fuadilah Mulyadhien, This isn't enough information to solve the problem. The original error message referred to the rule actor (which is not necessarily the same as the rule author) not having sufficient permissions to perform the transition. So,
Hi @Kelly Arrey
I solve my problem already, several issue that I fix are:
- the rule actor, the default one is not given permission, so modified the actor, and the
- the JQL issue , somehow:
status = "To Do"
is not equal
status = "TO DO" -> this one worked out
- JQL option modified to " Some match specific JQL"
After I modified those 3 item, the automation worked out fine.
