The use case is to link similar issues within a project. The rule needs to check 'similarity' when new issue is created.
It seems like a really simple one, but it doesn't work, issues are not linked:
To test the rule I pick any ticket in the project and create the same with slight modifications or without them at all to increase the chances of 'similarity', but Audit log says:
What do I do wrong?
We had a bug recently with a Similar issue description not working for JSM and it was fixed yesterday - https://jira.atlassian.com/browse/AUTO-902.
It should work for JSM now and as @Jack Brickey stated it is only JSM issues. It is still not implemented for Jira software project issues. Hence, it doesn't work on Jira issues.
Thanks for that update, @Nanda
Do you know why that branch type is listed for rules in Jira Software projects, even when JSM is not installed?
I suspect that initially there was a plan to introduce this to Jira Software as well and then it must have been deprioritised.
I have requested to remove the components which are not compatible with JSW projects from the list in Automation section of Software projects.
Also created a feature request for this to be implemented in JSW projects - https://jira.atlassian.com/browse/AUTO-904
hi @Dolores Rhyme ,
I may be mistaken but I think similar issues only works in JSM projects. I will research a bit. Can you test in JSM if you have it?
Thank you @Jack Brickey for a quick response. I'll check that and get back. You're an expert here, maybe you saw something to address this case for Jira Software? I'll truly grateful for this.
I am really not sure how you could do this with automation. It really take a good AI engine to identify "similar". If the issues had the same Summary maybe you could save the new issue Summary into a variable (newSummary) and use in a JQL ~ "{{newSummary}}". but I don't see this working TBH.
FWIW, here is an old post on Similar requests I posted a couple of years back - Similar-requests-what-do-you-guys-think-about-this
I've checked the same settings for JSM but Audit log says the same. Interestingly: I've enabled the Similar issues feature in JSM, and it finds the same issues, but he ruke - doesn't.
I miss something in settings I suppose...
Interesting. I have never played with the similar issues branch but let me give it a try. Questions for you...
I was thinking about the following if creating something like this 'manually': there's JQL 'text' that checks both summary and description on all the tickets in the backlog and finds similar by the text you mention in this JQL. If there were a possibiluty to check a newly created issue's summary and description with this rule, that could be a way out, but I'm not sure if it's possible.
I tested it with different tickets. I just pick any ticket in the backlog, then create the same one (summary and description). It never works out.
So I played with the similar requests branch and it really does not seem to work or I'm completely missing how to use it. I even created a clone and adjusted the slider bar to many variations and it never found the clone. The only time I had any sort of 'success' was by adjusting the slider to not very similar and it found one issue with one matching word in the summary. Long story short I just don't see it this is reliable at all to be honest.
I also think so... Why to roll out such a broken rule then:(( Very frustrating to spend so much time for something that doesn't work. I really appreciate your help. You're a definitely a community leader!
Thanks Dolores, always glad to help where I can. I'm reaching out to Atlassian colleagues for input. Unfortunately, I do not have access to Support directly so cannot ask there but you may wish to do so. If I find out more I will share it here and would appreciate any for the findings on your part as well. Cheers!
Interestingly that branch type is available in rules even when JSM is not available, like in my free Jira Cloud instance. I wonder if there is some crawling process that needs to happen (once similar is enabled) before the results are returned.
