Automation rule for transition "Issue commented" triggers during transition with comment screen
Dave Kleihorst
Automation rule is setup as follows:
Trigger: Issue commented
Issue field configuration: Status in ("Waiting for customer", "waiting for external party")
Action: Transition from "Waiting for customer" to "To Do"
In my setup I've used a simple "Comment" screen during transition from "To Do" --> "Waiting for customer". When I use the transition from "To Do" to "Waiting for customer" and I add a comment during this transition, the issue immediately goes back to "To Do".
How can I prevent this behaviour? I've looked into te post-function of the transition to switch the order of the following two, but you cannot change that.
  1. Set issue status to the linked status of the destination workflow step.
  2. Move up Move down Edit DeleteAdd a comment to an issue if one is entered during a transition.
Could someone help me out?
Thanks!
Adam Rypel _MoroSystems_
Hello @Dave Kleihorst ,
So when the customer comments on the issue, you need it to go back to "To Do", is that correct?
Just to make sure - do you need that for Jira Software project or Jira Service Management?
Adam
Dave Kleihorst
Hi @Adam Rypel _MoroSystems_ ,
That's correct. Unfortunately I'm not able to do a check of the commenter is a "Customer", because in this environment people can be "Service Team Member" and Customer (not ideal, I know).
It's indeed JSM.
Like Pedro Silva likes this
I understand, thanks for the details.
One option that came to my mind how you could adjust the automation:
  • Add condition User who triggered the event is Reporter
    • If user can be also an assignee, then add condition User who triggered the event is not an Assignee
Would that be applicable?
Adam
Like # people like this
Dave Kleihorst
Thanks @Adam Rypel _MoroSystems_ ,
I've used "not in project role" that helped! Reporter was a good suggestion, but I would like to have it reopened as well when another Organization-colleague of the reporter comments.
Thanks for helping me find the solution!
@Dave Kleihorst glad you sorted it out!
