I'm setting up a Service Management project that handles tickets created by an API (from Collibra) as well as user-entered requests from the portal. I have an automation set up to auto assign tickets on create but it doesn't work for the API-generated tickets. According to the automation log, it doesn't run at all for those. Is there a different trigger I need to use for API tickets? Or a trick to get the automation to see them?
Thx!
And the magical power of asking somehow solved the problem. Without making any changes, the same automation that never worked this morning is suddenly working when I went back to take screen shots <facepalm>
For an automation-related question like this, please consider posting an image of your rule and the audit log from an execution of it. That will provide context for the community to offer you suggestions. Thanks!
Best regards,
Thanks! I'm confident that I will have more automation questions in the future. I'll make sure to include that info.
