Hi!
I need to come up with an automation rule that does the following:
- Runs search for issues in a project
- Sends separate emails to reporters with the following info:
- List of issues that they reported
Problem: far I can only come up with a filter that sends a list of all issues to all reporters. What I need is for every reporter to receive an email with only the issues reported by him / her
Please create a filter reporter=currentuser and project =your project
Create a group whome you interested to send emails, add users and subscribe this filter to that group . For filter frequency, you can set as per needed.
Now each reporter will receive email with issues they reported.
Please change the above query as needed
I still have a question. I run a search based on the following filter:
Project = "X" and StatusCategory !=Done
Should I add the reporter = currentuser to this filter?
Who should the email be sent to? There is a "reporter" option, but so far every reporter receives a list of all issues. will this reporter = currentuser solve the problem?
Yes, please you need to add it in the query otherwise, user will receive all issues.
If you add that part then user will only receive issues which they reported.
The rule failed:
As there is no issue present, cannot get the value of the field:assignee
However, the filter gave out two issues, in both of them I am the assignee.
Could not send email, the 'To' address field is empty. If you have referenced a field it may be empty.
In the rule I stated to send an email to assignee.
Can that happen because the autorul runs for a Next-Gen project, and assignee field has some different parameters in JIRA?
No need to create a rule, please just create a filter and subscribe the group to that filter
1) Create your Query and save it
2). Go to Details and click on New Subscription
3). Now select the Schedule Daily and set the Interval as per your needs
Add the group which include users
Oh, I see. That solves a lot of my future problems, thanks!
Well, as for the automation rule I only need to run it once, and post a message both to email and to Slack channel for people to clean up the JIRA project. And I am dead curious to know how to do that with automation for future reference, although your answer helps!
