Hello, I am struggling trying to set up an automation and hope someone can help.
What I am trying to achieve:
I found some posts from 2020 but not sure if they are still relevant or things have improved since then!
Hi @Chris Morphew ,
Welcome to the Atlassian Community.
In an automation rule you can use a branch. In the sector you choose 'linked issue'.
See screenshot for an example.
regards, Marco
Thanks Marco, sorry only just getting back to this.
I found the branch setting that detects a change in a linked issue, but I must be being dense, what do I select for the main initial trigger? Feels like a kind on inception as the trigger is the fact that the linked issue has transitioned, i.e. nothing changes on the 'parent' task?!
Hi @Chris Morphew ,
You set the trigger on the transition of the issue in one of the separate Jira projects.
And in the branche you set up the transition from the 'parent' service management issue.
Regards, Marco Brundel
y
