Hi, I'm using Automation for Jira to transition parent tasks to Done when all sub-tasks are moved to Done. I wonder if it's possible to perform the transition automatically without need to manually confirm it in appearing modal dialog.
Hi @Alexandr Karlin -- Welcome to the Atlassian Community!
Would you please post and image of and describe the modal dialog which is appearing, and under what conditions?
I hypothesize that has nothing to do with the automation rule, and instead is related to something in your workflow, or perhaps from an addon. Instead I would expect an automation rule which tries to make a change to an issue that has a required field would fail with an error in the audit log.
Hi Bill,
Thank you for your answer. Please see the following image describing the modal dialogue appearing when drag-n-drop a sub-task which is the last one for a parent task, on the project board.
Thanks for that information, Alexandr.
That modal dialog is built into Jira, and there are several suggestions to disable it, for example:
You may vote for/watch those to see any progress.
Thank you, Bill! Thumbed up for both suggestions.
