Block commenting for closed issues
Robert Varadi
Hello, i would like to block users to comment on close issues.
I saw an older article, but it is for JIRA datacenter version, and i am using JIRA cloud.
Can i have a list of parameters and their description for JIRA cloud?
2 accepted
3 votes
Guilhem Dupuy
November 14, 2022
Hello @Robert Varadi ,
You can parameter this in the Worflow, by adding the following property to the statuses where users shouldn't be able to add comments anymore :
jira.permission.comment.denied
This will disable the permission to comment issue for the statuses it is added to.
Let me know if it helps,
Guilhem
Robert Varadi
Thanks very much. it worked
Like Guilhem Dupuy likes this
Mohamed Benziane
Welcome to the community
I think this document might help you
https://support.atlassian.com/jira-cloud-administration/docs/use-workflow-properties/
Robert Varadi
Thanks. very helpful
