Is there a way I can create automation rule using the value in Project category?
While creating a Project there is no way to select the Project Category. (Is there a way we can select Project Category while creating a Project?)
Scenario:
So after a project is created, if I go and update the Project Category for the Project and Save. Based on the category selected/saved, can I run an automation rule? If yes, can you please help me how to do this?
Thank you
Hi @Shan (SHPK)
Adding onto Jack's answer:
It seems {{project.projectCategory.name}} is not working when the automation rule is triggered on create issue. Any tips?
Hi @Alis-Hathway Ward (DO NOT USE)
You could try to access the field from the issue to see if it is available:
{{issue.project.projectCategory.name}}
If it is not available, you could instead call the REST API to get the project information.
This is not possible. Automation works on issues not projects.
