Can I create an automation rule using Project Category?
Shan (SHPK)
Is there a way I can create automation rule using the value in Project category?
While creating a Project there is no way to select the Project Category. (Is there a way we can select Project Category while creating a Project?)
Scenario:
So after a project is created, if I go and update the Project Category for the Project and Save.  Based on the category selected/saved, can I run an automation rule?  If yes, can you please help me how to do this?
Thank you
Bill Sheboy
May 5, 2022
Hi @Shan (SHPK)
Adding onto Jack's answer:
  • No, you cannot trigger an automation rule based on a change to a project field; only create project triggers (I believe...)
  • And, project category is accessible in a rule as {{project.projectCategory}} for all the object or just the fields you want, such as {{project.projectCategory.id}} or {{project.projectCategory.name}}  So if your rule is triggered in another manner it could use the category information.
Shan (SHPK)
Thank you @Bill Sheboy  for sharing the details.
Alis-Hathway Ward (DO NOT USE)
It seems {{project.projectCategory.name}} is not working when the automation rule is triggered on create issue. Any tips?
Bill Sheboy
August 9, 2022
Hi @Alis-Hathway Ward (DO NOT USE)
You could try to access the field from the issue to see if it is available:
{{issue.project.projectCategory.name}}
If it is not available, you could instead call the REST API to get the project information.
Jack Brickey
This is not possible. Automation works on issues not projects.
Shan (SHPK)
Thank you @Jack Brickey
