Hi! Here's the problem I have.
I want to solve next task: change task's status when status of linked issues changed to Done. Type of link is "blocked by".
Problems starts at step 1 - choose a trigger for the rule. Cannot find trigger that tracks linked issues status.
Do you have any ideas?
Hi @Vladimir Tarusov and welcome to Community!
You can actually do it the other way around. Let's say you have 2 tasks: Task A is blocked by Task B. You need to add a rule like this:
It would look like this:
Hope this helps!
- Manon
@Manon Soubies-Camy hi and thanks for welcome!
It seems the way for cases when we have only one Task B that blocks Task A.
If we have also Tasks C, D, E that also block Task A, the status of A should be changed only when all (B, C, D, E) are Done.
I have no idea how to look for all of them.
Thanks for the additional details, I think it would work with something like this:
Not sure of the link types, I'm always confused between "is blocked by" and "blocks", so you may need to adjust them :)
Aha! I get the point. Thanks a lot for your help.
