Hello community,
trange thing. I created two custom fields and used them within a project on different screens. Afterward I needed to change the description of the custom fields. Then the changes will not be shown if I create a ticket but the old descriptions appear. If I look in the configuration everxthing is ok. I reindexed Jira but this did not solve the problem.
Has anybody an idea what I missed to do?
Thanks in advance
Manfred
Hi Manfred - You need to modify the Field Configuration for that project. You can find directions/help here:
https://confluence.atlassian.com/adminjiracloud/changing-a-field-configuration-844500798.html
Ups, that was my mistake. The field configuration can adjust fields (i.e. the description). The problem as that I changes the field itself after I added ist to the field configuration.
arghhhhh! Thanks for the quick answer.
Manfred
