Comment Post Function, Sent by the Project Lead
Gavin Minnis December 19, 2018
I am using the following script in a ScriptRunner Post Function to automatically add a comment on transition:
import com.atlassian.jira.issue.comments.CommentManager
import com.onresolve.jira.groovy.user.FieldBehaviours
ApplicationUser currentUser = ComponentAccessor.getJiraAuthenticationContext().loggedInUser
def wertreporter = issue.reporter.displayName
def reporter = "Hello *" + wertreporter + "*,\nThis is an auto-generated comment."
CommentManager commentMgr = ComponentAccessor.getCommentManager()
commentMgr.create(issue, currentUser, reporter, true)
How can I control who creates the comment? Right now, it appears to me that the person who transitions the issue is the "currentUser" and thus creates the comment. (BTW, in case it matters, this transition occurs from a Service Desk approval step.) I prefer that the comment be made by the Project Lead or some other user that I can define.
Any help would be greatly appreciated.
Carmen Creswell [Adaptavist]
December 19, 2018
Hey Gavin!
You should be able to use this modified version of your code to achieve your goal. This gets the project lead instead of the currentUser.
def myProject = issue.getProjectObject()
def projectLead = myProject.getProjectLead()
commentMgr.create(issue, projectLead, reporter, true)
Gavin Minnis December 20, 2018
Carmen, thank you! That worked perfectly.
