I have an automation to send a Slack message with the values from an issue form. This form has 10 potential setpoints that can be filled so I wrote the logic below expecting it to check if each value is filled and then print out the values. I got it to work for 1 setpoint but when I duplicated it for all 10 it breaks and I get the error below.
Logic:
<@U08C1SD8EJY> New Setpoint Change Request
Requester: {{reporter.displayName}}
{{#if(exists(issue.customfield_10424))}}- {{issue.customfield_10424}} - Current: {{issue.customfield_10428}} - New: {{issue.customfield_10429}}
{{#if(exists(issue.customfield_10457))}}-{{issue.customfield_10457}} - Current: {{issue.customfield_10458}} - New: {{issue.customfield_10459}}
{{#if(exists(issue.customfield_10460))}}-{{issue.customfield_10460}} - Current: {{issue.customfield_10461}} - New: {{issue.customfield_10462}}
{{#if(exists(issue.customfield_10463))}}-{{issue.customfield_10463}} - Current: {{issue.customfield_10464}} - New: {{issue.customfield_10465}}
{{#if(exists(issue.customfield_10563))}}-{{issue.customfield_10563}} - Current: {{issue.customfield_10564}} -New: {{issue.customfield_10565}}
{{#if(exists(issue.customfield_10566))}-{{issue.customfield_10566}} - Current: {{issue.customfield_10567}} - New: {{issue.customfield_10568}}
{{#if(exists(issue.customfield_10569))}-{{issue.customfield_10569}} - Current: {{issue.customfield_10570}}- New: {{issue.customfield_10571}}
{{#if(exists(issue.customfield_10572))}-{{issue.customfield_10572}} - Current: {{issue.customfield_10573}}- New: {{issue.customfield_10574}}
{{#if(exists(issue.customfield_10575))}-{{issue.customfield_10575}} - Current: {{issue.customfield_10576}}- New: {{issue.customfield_10577}}
{{#if(exists(issue.customfield_10578))}-{{issue.customfield_10578}} - Current: {{issue.customfield_10579}}- New: {{issue.customfield_10580}}
Error:
Short answer: several of your conditional expressions are missing one of the right-curly brackets, and the error shows the location of the first one near customfield_10566.
I recommend writing long expressions like this in a text editor which supports bracket matching. This makes it easier to see errors and fix them. When done, copy and paste into the rule for use.
Adding to @Bill Sheboy answer - here is fixed code (thanks to ChatGPT)
{{#if(exists(issue.customfield_10424))}}-{{issue.customfield_10424}} - Current: {{issue.customfield_10428}} - New: {{issue.customfield_10429}}
{{/if}}
{{/if}}
{{/if}}
{{/if}}
{{/if}}
{{#if(exists(issue.customfield_10566))}}-{{issue.customfield_10566}} - Current: {{issue.customfield_10567}} - New: {{issue.customfield_10568}}
{{/if}}
{{#if(exists(issue.customfield_10569))}}-{{issue.customfield_10569}} - Current: {{issue.customfield_10570}}- New: {{issue.customfield_10571}}
{{/if}}
{{#if(exists(issue.customfield_10572))}}-{{issue.customfield_10572}} - Current: {{issue.customfield_10573}}- New: {{issue.customfield_10574}}
{{/if}}
{{#if(exists(issue.customfield_10575))}}-{{issue.customfield_10575}} - Current: {{issue.customfield_10576}}- New: {{issue.customfield_10577}}
{{/if}}
{{#if(exists(issue.customfield_10578))}}-{{issue.customfield_10578}} - Current: {{issue.customfield_10579}}- New: {{issue.customfield_10580}}
{{/if}}
