Hello
could you help please?
I have six transitions with the same name from one status, three transition for one status and three transitions to another.
On this transitions I have Conditions
Value Field | Allows to execute a transition if the given value of a field is equal to a constant value, or simply set. |
each transition has similar conditions, to move an issue trough the statuses(values of two fields should follow)
this ruls not work, I don't see that transition that satisfies the requirements.
Transitions that possible is incorrect
Thank you!
Hi @Proshkin Kirill,
Your screenshot makes it almost impossible to judge why you are not getting the desired result, as the key information to assess what you are trying to check is blanked out. But it has almost certainly to do with the grouping you are trying to use.
As it is set here, if any of the conditions in the inner group is true AND the last condition is true, this transition will be visible. So either no conditions at all from the first block are true OR the last one isn't true. If you look at the issue you are trying to transition and think that this is not correct, there is something wrong with the way you are trying to check the value of the fields (compared as string). But in that case, you'll need to look into the specific field that you are evaluating and find out why this compare as string is not evaluating as expected.
Hope this helps!
Thank you @Walter Buggenhout and I apologize for the lack of information.
resolve my problem, it was not in transitions, while creating validator one of them was with wrong string value.
thank you
and have a nice day
