Configuration Problem Error
Mitch Wiemans December 10, 2018
I have removed some custom fields which we don't use anymore.
After I have deleted them, we are getting the following message when opening a project:
When I view the error, I see the following message:
This is indeed a field which I have removed and may be in use by something.
But how can I check this / get rid of this error?
I can't find this field anywhere since we deleted it.
Thanks in advance!
Mitch
Thomas Deiler
Dear @Mitch Wiemans,
it seems that you have found a sanity bug in JSD. It should not be possible to delete custom fields, when you cannot remove them later manually from the configuration.
To fix this, I fear that you have to reconfigure your affected project from scratch. But before try to run re-index and integrity checks.
So long
Thomas
Hi Thomas,
thanks for the answer.
I have reconfigured the project without success. I think I should start it from scratch (Which is not a big problem since it was still a test project).
Thanks for the information!
Mitch
