Hi there,
I've created a company-managed project in Jira Work Management and am automating subtasks to be created when a task is created. These tasks are automatically being scheduled with an automation using business days for start and end dates, something like this:
{{now.plusBusinessDays(20)}}
However, there are some weekdays that I want subtasks to skip — the days our agency is closed for holidays throughout the year.
For instance, this year, we have Friday, 12/23 and Monday, 12/26 off for the holidays. If I have a task that takes 3 days and starts on Thursday, 12/22, I would like it to skip over Friday and Monday and have the task continue throughout Tuesday, 12/27 and be due Wednesday, 12/28. Or if the task would originally be slated to start on Friday, 12/23, with the original automation, it would actually begin on Tuesday, 12/27.
I've seen that you can configure Working Days in Software Projects but I'm not seeing a similar feature in Work Management Projects. Is there such a feature available? And if not, what automation or other feature could I use as a substitute?
Thanks very much in advance!
Hello @Emma Hecht
The ability to configure working days is not available for Work Management projects. You can vote on the change request here:
https://jira.atlassian.com/browse/JWMCLOUD-208
I haven't yet come up with a scheme for working around that, but if I think of something I will post back here.
That's good to know. Thanks, Trudy! Added my vote there.
@Bill Sheboy / @John Funk — Do either of you have any suggestions on question above (how to implement something similar to Working Days in Jira Work Management)? Thanks!
Hi @Emma Hecht
Yes, and...to Trudy and John's information...If you search the community you will find lots of attempts to implement this use case to work in rules. At this time, I believe the only work-arounds are:
More info: two limitations which prevent automation for Jira rules from doing this are the built-in date/time functions do not use the customer-defined, non-working days in projects; and, created variables cannot be used in smart value list filtering or functions.
@Bill Sheboy Thank you! I'm going to work on the REST API with my team — thanks for all of these suggestions!
@Bill Sheboy I had my IT team write a REST API and it works perfectly! Thanks so much for this suggestion.
For anyone it may help, posting a few screenshots here. I wasn't involved in writing the REST API, but here is how I called it:
