×Dear community,
I have done already a few automations in JIRA for our setup, like create a "Story" and copy descriptions from the created issue in another projects (global setting for multiple projects).
Now we have the requirement to copy the acceptance criteria from the Story in Project #1 to the initial Business Feature in Project #2.
I created this Automation:
If in the current issue the value for "Testfallbeschreibung" changes, copy the value to the linked issue and add a comment.
Adding the comment works, but for some reason the description is not copied.
Do you have any ideas?
BR Damian
This should be work with this:
Wow, great! It works. I use it now for custom fields. Thanks a lot.
Just another short question. I have a checkbox attribute that I would like to copy but unfortunately there is no option to use the smart fields. Any ideas?
You can try somthing like this :
{{issue.customfield_name.value}}
Oh man, so dumb. Once you post the smart template you have to activley press the typeahead, otherwise it doesn't save it.
It works now... damn :D
