Create a commit and pull request from Jira to Bitbucket
nico kalde
March 7, 2024
I'm trying to take the description from my issue and when issue transition from "to do" to "in progress" create a branch, commit the description from the issue in a json file into a folder in bitbucket and then create a pull request.
Can I do this with any tool of Jira Service Management?
Aron Gombas _Midori_
I don't think that there is a app available for this purpose, as it sounds overly specific.
But, all the components provide APIs and you can always use ScriptRunner and custom Groovy scripts to solve specific automations.
You would need:
  1. a listener in Jira that captures status changes
    1. access the issue details
  2. connect to the Bitbucket REST API and
    1. create a commit
    2. create a PR
nico kalde
March 8, 2024
I will try to use ScriptRunner for this automation.
Thanks for your answer!
FREE
