Created Vs Resolved Chart problem
Dan W
April 23, 2020
We have noticed that the chart when set to daily the first day isn't showing the correct counts.  For example, if I set the days to 7 April 16 says 121 created.  If I set it to 14 days April 16 says 237 created.  What would cause this discrepancy?
Moses Thomas
@Dan W   You may need to check whether you are geting results based on a filter or  the entire project.
Dan W
April 23, 2020
I am using a filter.  I wasn't changing the filter I am using so I didn't think that should change the results.  I use the same filter to display a daily, monthly and yearly gadget.  The monthly and the yearly don't seem to have the problem.  Just the Daily and it is always the first day of the gadget graph.
