I need to make custom priorities for each project in Jira, well mostly i need to change them in one project that needs 5 priorities instead of the standard 4, but i need it to not reflect the whole account, just the one project ...
can this be done ?
Hello @Michael Horbye ,
Can you please explain a bit clear.
If the project with shared "Priority Scheme", if a change has been implemented on the permissions. it will impact the other projects.
Please make a copy of the "Priority Scheme" which applied on the current project. and apply changes on this copied "Priority Scheme", and associate with the required project.
Anvesh Kagithala
I have a project that need to have 5 priorities instead of 4, but when i try to change it, all my projects have 5 not 4 :D
So i need a way to have this one project have its priorites :)
How do i make or find Priority Schemes ?
Hi Sorry, the above solution is for "On-premise" Server and Data center.
Please check the below jira ticket.
https://jira.atlassian.com/browse/JRACLOUD-26779
You may need to create a new custom field for this purpose with required values.
thank you very much, huge help :D i will look into custome fields for my needs
