Error rendering 'com.atlassian.jira.jira-view-issue-plugin:timetrackingmodule'. Please contact your
Mouna Hammoudi
September 19, 2023
0
I have gotten the following error for a Jira issue just after changing the issue components (I have added a new component). As a result, my automation for Jira rule is no longer working.
Error rendering 'com.atlassian.jira.jira-view-issue-plugin:timetrackingmodule'. Please contact your Jira administrators.
Kseniia Trushnikova
Hi @Mouna Hammoudi,
I've found this article in the Jira KB: Error rendering 'com.atlassian.jira.jira-view-issue-plugin:timetrackingmodule'. Please check if you have the error mentioned in the article in the atlassian-jira.log.
Mouna Hammoudi
September 19, 2023
@Kseniia Trushnikova
I have tried it and it is not returning anything for the diagnosis so the solution they are suggesting is not working.
Kseniia Trushnikova
@Mouna Hammoudi, then I'd recommend you to create a support request at https://support.atlassian.com so the Atlassian support can analyze the logs of your Jira instance.
