I've created a custom labels field called "Issue context". What I'd like to do is combine several fields into that context field when an issue is edited, including:
1. Two single-valued custom fields
2. The issue components
3. Any labels
I have a basic automations set up, but it's creating entries with spaces as if they are multiple labels.
When I use smart values such as:
{{issue.customfield_10117.value}}
I'll get one label set per word.
Escaping it with:
{{issue.customfield_10117.value.asJsonString}}
Still gives me one label set per word, but with quotes :
Any ideas?
Hi Andrew,
I don't think I have answers for you for getting rid of the quote marks, but I am curious what you are actually trying to accomplish. Maybe there is another route to go.
We're taking several common labels and turning them into dedicated fields or components. However, we've now hit more fields than are allowed to be rendered on the kanban board, so I was hoping to join them all into a single field for display there.
Take a look at this article and see if the combining of fields section helps:
https://support.atlassian.com/jira-software-cloud/docs/smart-values-lists/
It looks like either the docs or the app have a bug. Pasting in the example call to join the fixVersions field isn't accepted.
{{issue.fixVersions.name.join(" - ")}}
Typing it in by hand doesn't work either, because as soon as I press the space bar it closes the smart value.
You should probably go ahead and submit a Support Request to Atlassian then. If you don't mind, post back here what the solution was so we can close it out. :-)
Support reminded me that labels can never have spaces in them, which is why this wasn't working. Switching to a plain text field fixes this. Thanks for the suggestions!
